earcaesar
#1 Posted : Thursday, March 26, 2015 5:50:26 PM(UTC)
earcaesar
Have a dryer that is not drying well anymore. Have to run it 2-3 times before it will dry a normal load.
I vent inside the dryer is fully clear and no blockage. When I take the vent off and try and dry a load it did not dry well at all.
Heat does come out of the dryer with the vent off and it seems to blow pretty good.
Not sure what the issue is.
earcaesar
#2 Posted : Sunday, March 29, 2015 8:03:29 AM(UTC)
earcaesar
Any suggestions? Not sure what parts might be the problem as to what would cause the dryer not to dry in 1 cycle of a normal load. Might it be the blower? and if so what is the part number?
