my Frigidaire {phs67ehsb3} ice maker is not producing ice...it gradually started to make less over about a week...the ice maker makes ice if I manually pour water into it...I took the ice maker out and defrosted it....no change...I switched the wire for the water dispenser with the wire for the ice maker on the water valve and when I pushed the dispenser...water came out of the hose going to the ice maker...there was good water pressure....is there a chance that the ice maker solenoid is bad and would that be located behind the plate on the front of the refrigerator where the water and ice come out
Here are your parts Parts for Frigidaire PHS67EHSB3 Refrigerator - AppliancePartsPros.comHere is the tech sheet http://manuals.frigidaire.com/p...f/Anderson/240389633.pdfI am assuming that when you filled the ice maker tray with water it froze and ejected the ice cubes normally and that it just did not refil the ice maker tray. [COLOR="Blue"]is there a chance that the ice maker solenoid is bad[/COLOR] I am not sure what solenoid you are referring to. Could be that the water valve is bad. Below is a link to a site that has manuals. You will have to join the site and be logged in to ba able to download a manual. http://appliancejunk.com/forums/index.phpAlthough there is not a manual specific to this unit there are two Frigidaire manual which may be useful to you. Frigidaire Refrigerator Next Generation Side By Side Service Manual and Frigidaire SxS Refrigerator SM With Genesis Controls (5995413142) Service Manual |
THIS FORUM IS DEAD!!!!!!! |
