I just fixed the tub seal on my washing machine and now it won't spin if there are more than a few items in it. If I have a load in it will agitate and drain but won't spin will just hum. When I remove most the load and leave 1 or 2 light items it will spin. I checked to make sure there are no clogs, not sure what to do next would appreciate any help
If you will post a model number so we can see exactly what machine you have someone may be able to help you.
Ok, this is a standard GE model with a regular transimission.
Operate it with the front panel off and see what the motor, belt, clutch and transmission are doing in the spin cycle.
