FrustratedGeminiOven
#1 Posted : Sunday, March 15, 2015 10:45:08 AM(UTC)
I have a Maytag Gemini electric stove with two ovens. The lower oven won't heat past 200 degrees. I ordered and installed a new heating element - that was not the problem.:confused: PLEASE HELP!
#2 Posted : Thursday, March 19, 2015 2:57:25 PM(UTC)
took the sensor probe out and checked the Ohms it's working fine.
#3 Posted : Sunday, March 22, 2015 2:50:43 AM(UTC)
Parts for Maytag MER6751AAW Range - AppliancePartsPros.com
See that attachment for the tech sheet.
If the oven indicates that it is ready (finished pre-heat) then it is probably the control board.
If the unit stays in pre-heat and both the bake and broil elements are OK then it is probably the control board.
File Attachment(s):
MER6751.pdf (717kb) downloaded 2 time(s).
Guest (4)
