Reza.darissavi
#1 Posted : Saturday, March 14, 2015 10:12:27 PM(UTC)
Reza.darissavi
I purchased a thermostats, 8170850, for KitchenAid fridge model KBRA22KLSS01. The thermostat has two terminals, L and C. The two wires on the fridge, that suppose to be connected to the two terminals, are red and light grey. I need to know which of the terminals, L and C, should be connected to red wire and which other get connected to the light grey. Thank you so much in advance for your help.
#2 Posted : Monday, March 16, 2015 4:26:43 AM(UTC)
Since you are controlling AC it should not matter.
As long as one of the connectors you list is not earth ground.
Reza.darissavi
#3 Posted : Monday, March 16, 2015 4:34:23 PM(UTC)
Reza.darissavi
Thank you so much for your reply.
just to make sure, why one terminal is marked by L "line" and the other C "common"?
Also What are you referring as AC?
Rez
#4 Posted : Tuesday, March 17, 2015 12:49:23 AM(UTC)
AC is alternating current ( normal house current ).
