When going thru cycles it stops and starts all the way . Also doesn't completely spin out as well as it should. Both things started happening at the same tions.
If you could post a full model number, which should be three digits, usually 110 or 417 followed by 8 digits we will be able to tell which model you have and may be able to help.
