AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
DG 612 Moisture Sensor Location? And how to replace?
Groups: Expert
Well, you should probably call in a tech as you really need to check voltages to see why your not getting power to the timer motor when the thermostat cycles.
Eric
could it be caused by a bad thermostat(s)? If I'm going to take it apart to check the wires, I'm thinking it would be worth it just to replace the thermostats if they could be the cause.
Groups: Expert
Possibly, but I think unlikely that both of them are bad.
Eric
Here's some more info I should have had to start with: on low temperature, the auto shut-off works fine. So it's only on the regular temp setting does it fail to auto-shut off. Does this make it more likely that the high temp thermostat has failed? If so, can you tell me which part number? I'm thinking if I'm going to take it apart, I might as well replace it while I'm there. Unit is 20+ years old... thermostat won't last forever. Thanks.
Groups: Expert
Awesome. Thanks a million Eric.
It's on order. Any tips on replacing? It looks like I need to access from the back of the machine. Is there any easy way to tell the high temp thermostat from the low temp? Thanks again.
Groups: Expert
Access is from the front. Remove the two screws near the bottom of the front panel, tilt it out at the bottom and pull down to release it at the top. Unplug door switch or just move panel to the side. The stats are on the blower housing on the left. The regular stat operates at 150° and the low stat at 140°. They should be marked, L150 L140.
Eric
So I replaced the thermostat, but it still won't shut off automatically. Any ideas on what else to do?
Thanks,
Greg
am having same problem [ timer won't advance when using moisture control but will advance when using timer side of control] thanks for all thought on this problem.
Dryer Repair
