I just bought a brand new Samsung washer and dryer. I did not realize that it was a HE washer, so it doesn't use a lot of water to wash the clothes. At first I wasn't too concerned, but now I'm noticing that, in big loads, a lot of clothes do not get fully wet in the wash cycle.
In older Samsung washers, you could adjust water levels by adjusting the pressure switch. But this version uses a pressure transducer.
Does anyone know how I can hack a a pressure transducer (or some other component) to add a bit more water?
I don't want a top-loader-volume of water -- just enough to ensure everything gets fully soaked in the wash cycle.
Thanks!
I have the same problem--not enough water. How do we make the adjustment?
