dude19572
#1 Posted : Friday, May 15, 2009 7:32:00 AM(UTC)
dude19572
I Replaced The Thermo Fuse About A Month Ago And It Ran Fine For About A Month Then It Blew Again Now It Only Lasted About A Week What Could Be Causing This To Happen ????
#2 Posted : Friday, May 15, 2009 2:49:35 PM(UTC)
It could happen if the water temperature is too high or the motor drawn more current than it should. The motor amperage should be written on the name plate on the door frame.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDL02IRBS1 | AppliancePartsPros.com
