Our washer leaks out during the spin cycle only, was wondering if it is the seal and how to replace if that is what it is. Mechanically inclined but first time with a washer. Belt just went bad also, any tips? Thanks for your time and take care.
Make sure the water level dial is not too close to reset. The machine may be confused; or the pump may have a crack. Pretty easy to replace and the belt can be done at the same time.
