nickynuc
#1 Posted : Thursday, May 14, 2009 12:14:10 PM(UTC)
nickynuc
Child lock will not disengage. How do I troubleshoot if its the sensor pad or contol panel?:confused:
#2 Posted : Friday, May 15, 2009 5:00:16 AM(UTC)
Have you tried removing power from the unit for an hour or so, to see if it will reset?
I have tried to find a pinout for the keypad for you but so far have not had any success. You really need that so the keypad can be checked with a meter to confirm that you have a stuck key.
Here is a tech sheet which may be of some use.
https://www.servicematters.com/d...0Sheet%20-%208051291.pdf
nickynuc
#3 Posted : Friday, May 15, 2009 3:07:31 PM(UTC)
nickynuc
Disconnected power for one hour, the unit started up and i ran a load. It got about 2/3 done and the unit went off. I tried restarting and the child lock engaged. I pushed cancel and after about 2 minutes the washer started to discharge water.
I disconnected power again to reset it and the dishwasher started to work. Do you think moisture is getting into the keypad/circuit board?
#4 Posted : Friday, May 15, 2009 5:27:03 PM(UTC)
Would be worth opening it up and taking a look.
