I just opened my refridge, and the display on top showed that the fridge side was 41 degrees and the freezer section was 23... I pressed the temp set to lower the temps, but this did nothing... This is the first time I have had any problem with the unit... Any suggestions? thanks in advance...
Thanks, I'll see if I can find it to test as in the video...
