kcchadmac
#1 Posted : Tuesday, October 30, 2007 9:53:41 AM(UTC)
kcchadmac
I recently replaced the door lock mechanism on the fwt445ges2 washer. I installed the new part that was re-engineered for this model including the new counter-weight. After following the cryptic instructions, I ended up with an extra wiring harness. It is a two blade male harness with a pink-red wire and a white wire leading into it. For the life of me I cannot figure out where it goes. Also, the washer will not go into fast spin mode. I'm guessing it has something to do with the extra harness??? Thanks in advance for your help.
heyingh
#2 Posted : Sunday, December 16, 2007 5:38:30 PM(UTC)
heyingh
I also have problem with door lock. I find the part from internet and find there is a big part like arc. Shall I have to remove this part? How can i remove it? Shall I have to remove the front panel or ring-tub?
thanks,
heyingh attached the following image(s):
