wall
#1 Posted : Thursday, February 5, 2015 2:41:27 PM(UTC)
wall
Please help. My GE washer will only agitate on the delicate cycle. We usually only use the heavy duty cycle and today it wouldn't agitate. I tried it on the other cycles and it worked on delicate.
sidfink43
#2 Posted : Friday, February 6, 2015 1:00:22 PM(UTC)
sidfink43
Since it will operate correctly in one setting that suggests there is no mechanical problem with the washer and that the problem is with the control unit.
Part number: AP3775089
Before replacing it check all of the wires and connections to make sure something has not come undone.
There is a video that will show you how to change out the timer, and if you buy from this site and the new timer does not fix things you can return it.
