I can't get my Jenn-Air oven to turn on. The fan and oven light work; when I press any other control buttons I only receive a 'beep'. I think I may have hit some combination of buttons to cause this. I've tried cancel/enter, but doesn't help. Any ideas?:mad:
A Model Number may help others help you. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: dtaylo3  I can't get my Jenn-Air oven to turn on. The fan and oven light work; when I press any other control buttons I only receive a 'beep'. I think I may have hit some combination of buttons to cause this. I've tried cancel/enter, but doesn't help. Any ideas?:mad: I just registered to say that I had the same problem. I solved it by holding the timer button and pressing cancel.This was so frustrating because my wife will make the oven do this about once a month, and previously I was unplugging the whole range and plugging it back in. I recently figured out the button combination by trial & error, and wanted to share it.
