mrsteelxx
#1 Posted : Wednesday, January 28, 2015 7:05:23 AM(UTC)
mrsteelxx
I just replaced the slide bearings and support on the above dryer and also removed and cleaned the lower drum support for lint. Now the dryer will not run any more than a couple of minutes before shutting off. If I open the door and close it will restart right away. Any idea's on what the problem might be. If I just put it on air fluff it stays on.
mrsteelxx
#2 Posted : Thursday, January 29, 2015 1:10:34 PM(UTC)
mrsteelxx
Update to my post. Found the problem. If you have a newer model with the moisture sensor make sure the lead wires to it aren't pinched or disconnected.
