3MTA3
#1 Posted : Tuesday, January 27, 2015 5:00:29 AM(UTC)
3MTA3
I have a water leak at tubing coupler part number
"Tubing Coupler 218518700".
How is this part replaced? Is it a simple push on fitting, meaning do I just cut off the old coupler and push this one on?
The part is very expensive for a tiny plastic 90 degree elbow. Would it be possible to just get a .25 inch fitting of some sort at Ace hardware?
3MTA3
#2 Posted : Tuesday, January 27, 2015 5:05:59 AM(UTC)
3MTA3
The part is listed here as Water tube elbow - part AP2114732
Thanks.
3MTA3
#3 Posted : Tuesday, January 27, 2015 9:10:24 AM(UTC)
3MTA3
Just found the part I needed at Home Depot locally for $3.47 vs $22+ online - it is the same fitting btw. I have issue resolved and mods may delete this thread. Thanks.
