The main issue is that the wash will fill then drain, no advancement of the timer. Some times it works fine; some times you may need to bump the timer forward to complete the cycle. I replaced the timer with a unit I bought here, very easy install and it worked perfectly the first week. Now we are back to the same problem.
Please help before I utilize this fine machine for practicing my 1911.
Thanks! -Blake
Well off to the shooting range this POS goes, I will donate 230 grains of justice until satisfaction is achieved.
