When I start the dishwasher, it runs for 2 min. 15 sec. and then switches to Clean. Every once in a while it will run the full cycle. Maybe 1 out of 20 times or so.
I've replaced...
Control Panel Power Module Hall Sensor (latch on door side)
Nothing has worked.
Similar here, it starts, pumps, pumps again for a long time then goes to "clean." I found that if i open and then close the door during the second long pump sound it starts to draw water normally then is fine....strange. I think it might be the float switch? Just guessing.
Originally Posted by: tlux63 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) When I start the dishwasher, it runs for 2 min. 15 sec. and then switches to Clean. Every once in a while it will run the full cycle. Maybe 1 out of 20 times or so.
I've replaced...
Nothing has worked. I have exactly the same thing happening with my 4-year old Bosch SHE4AP! Someone please have the appropriate fix!
Originally Posted by: keese819 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have exactly the same thing happening with my 4-year old Bosch SHE4AP! Someone please have the appropriate fix! I wonder if anyone has been able to fix this. I too have exactly the same problem.
My dishwasher started a few years ago, where on the third cycle of noises, it only cleaned after we opened and shut the door. Now, I have to turn it on/off and do this and hope it completes the cycle. Very annoying and I have emailed Bosch and haven't gotten any find of response. Never buy another one.
