IxIGhosTIxI
#1 Posted : Wednesday, January 21, 2015 6:20:44 AM(UTC)
IxIGhosTIxI
My Maytag LAT5006AAE Washer will fill with water but will not agitate, spin, rinse,or drain. I've checked the lid switch/actuator and it clicks twice during the opening and closing function of the lid. The motor will not engage after fill up but the timer advances normally. No buzzing or humming except for the normal noise of the timer advancing. I can not get my hands on an Ohms meter to check continuity until tomorrow but my washer has been inoperable since Saturday. Is the problem most likely in the Lid Switch/Check Switch Assembly or Water Level Switch?
:mad::confused:
sidfink43
#2 Posted : Thursday, January 22, 2015 5:00:11 PM(UTC)
sidfink43
Since the timer will advance this means the lid switch is not the problem. So the wiring to the motor from the timer and/or the connections are bad, or the motor is bad or the timer is the problem. I am betting on the timer.
