augie0629
#1 Posted : Sunday, December 16, 2007 1:57:43 PM(UTC)
augie0629
Trying To Replace The Roller Drum. The Only Way To Remove Is By Removing The Set Screw In The Center. How Do You Remove The Screw? And Is There Any Way Of Doing This With Some Room From The Front? Thanks Paul
kawfeeman
#2 Posted : Sunday, December 16, 2007 5:55:18 PM(UTC)
kawfeeman
are you sure that there are not clips in front of the drum roller that can be removed ( using a specific tool for that clip ) by opening the clip up slightly and removing it then just sliding roller right off ( need to make sure belt is removed from tension pulley and motor..
