rayflower
#1 Posted : Monday, January 19, 2015 9:44:20 AM(UTC)
rayflower
So the dryer is running. The belt has been recently replaced. We have no heat. The blower is fine. The electricity coming to the dryer is fine. We have tested the heating element, Thermal fuse and thermostat. All good. The fuses in the fuse box are good. We are at a loss as to why the dryer won't heat. Any suggestions. :confused:
#2 Posted : Wednesday, January 21, 2015 1:21:19 AM(UTC)
Parts for Amana LEA90AW / PLEA90AW Dryer - AppliancePartsPros.com
Below is a link to a manual.
You will have to join the site and be logged in to be able to download it.
http://appliancejunk.com...wnloads;sa=view;down=404
[COLOR="Blue"]
The electricity coming to the dryer is fine.[/COLOR]
I am assuming that you have checked the power at the units terminal strip and you get 240 volts between L1 and L2.
Check the thermistor resistance, see page 9-8 in the manual.
Also you may want to try running the diagnostics.
