Wanda Elaine
#1 Posted : Sunday, January 18, 2015 1:10:38 PM(UTC)
Wanda Elaine
My Husband attempted to warm our kitchen by setting the oven on 400 degrees and opening the oven door. After about a half hour, the oven alarm went off and there was a small bit of smoke coming from the back. Now, the burners work fine but the top and bottom baking/broil elements don't heat up at all. I at first thought we needed to replace the elements but after reading through these threads, I'm thinking maybe it's the Oven Control Board? Also, if it is the Oven Control Board, would we need to replace the elements also?
BTW, I love this site!
#2 Posted : Tuesday, January 20, 2015 2:48:56 AM(UTC)
Parts for Frigidaire FEFL64DSF Range - AppliancePartsPros.com
Unplug the unit and remove the rear cover.
Inspect the wires and connectors to the elements from the control board and the terminal strip.
If all OK then odds are that the control board is shot.
You may also need a control overlay.
I cannot tell if this is a peel and stick. If it is then it often gets ruined trying to remove it.
Check the elements with a meter also check them for any bubbles etc. on their ceramic coating.
