Originally Posted by: Majortom ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The cooling fan runs you can feel the air coming out the top Right side grill unit overheats cooking potatoes. Think it is a weak Thermostat , is it under the turn table and if it is can I get to it From the bottom are do I have to pull unit. The model number is Mlo153uw. Ser number is 50403035. Is part number for thermostat ap4564957 Thanks Thomas Thomas, The thermostats you're interested in are located on the bottom of the microwave cabinet, behind the control panel inside the component cavity. You'll need to remove the control panel to access them. You'll be working near and around some high voltage components so be very careful, and don't touch anything other than the thermostats. We had some difficulties, using the model number you supplied, even in the manufacturers web site, so you may need to recheck and verify the information. Thanks
yes the number i put was wrong, it is mco153uw ser is 50403035 date is april 2005 thanks Thomas
Originally Posted by: Majortom ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) yes the number i put was wrong, it is mco153uw ser is 50403035 date is april 2005 thanks Thomas Yes, we decided to use that model number when researching for parts and locations, etc. The part numbers for the thermostats are: Part number: AP4564957
Part number: AP4564954
Once you access them, one thermostat will be a "closed" circuit. This is the safety thermostat, if the microwave gets too hot, it opens and removes power to the machine. The other thermostat will be an "open" circuit when the machine gets hot, or when cooking on the stove, the thermostat will close, and turn on the vent fan to cool the unit.
