Desperately seeking help. 3 women without a washer machine comes close to a crisis. Top loading washer machine problem is no water coming into the washer holding tub. When you turn the dial, only cycle that works is the SPIN cycle. Could it be the water inlet value or perhaps a fuse? Please advise and any diagrams, advice on how to find the problem and part number location so we can order a part? We are deeply grateful so for your professional help.Thank You.:confused:
before you call the repair guy, before you try to fix the timer, valve or water inlet please check the Fuse, I had the same problem but some extremely helpful post on the net from this guy ( thanks to him) I just replaced the fuse and the washer came back to life! Everything was working other than filling just because of the fuse which activates the water pump! Originally Posted by: lindavanzandt ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Desperately seeking help. 3 women without a washer machine comes close to a crisis. Top loading washer machine problem is no water coming into the washer holding tub. When you turn the dial, only cycle that works is the SPIN cycle. Could it be the water inlet value or perhaps a fuse? Please advise and any diagrams, advice on how to find the problem and part number location so we can order a part? We are deeply grateful so for your professional help.Thank You.:confused:
