lwenger63
#1 Posted : Thursday, May 14, 2009 2:45:45 PM(UTC)
lwenger63
I have a GE XL1800 Spacemaker over range micrwave oven. It will not heat food. Everything is operational, timer, carousel, lights etc.. It does appear to be making a louder then usual humming when turned on.Exhaust fan opens normally as well. Any ideas?
Thank you
applianceman
#2 Posted : Saturday, May 16, 2009 5:20:41 PM(UTC)
applianceman
I would say that the diode is bad causing the noise but almost always when the diode is bad the magnetron tube is also bad. Some microwaves have a 10 year magnetron tube warranty so you need to check into that before you attempt to repair this yourself. Microwave Repair Guide
