I have a Whirlpool Duet Washer that has a door that came open during a cycle. Now it will not lock. I know that it has to be a simple part that I need. I have already unplugged and restarted the machine many times.
you need a new Door Latch Mech. I would also replace the Strike mounted to the door!!!:)
Thanks very much. I will adhere!
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Door handle will not open. It will open, but it says controlled lock. I can’t get the door to lock.
