yep just checked on the wash looks as though no matter what cycle it is in it will not spins other than in the drain and spin cycle don't know what the problem is I would love to fix the washer since it is a brand new washer
Well... My washer just quit spinning as well. Maytag centenial commercial technology washer. I am not sure where to find the model number. Since the shifter has seemed to be the culpret do you think that I could just go ahead and order that?
Wood.
This what I got when I called appliance parts pros.. Which is advertised all over this website... Very professional and great tech service., Nathan, This is Robin with Appliancepartspros.com. The part we were discussing was the control board. The part number is**AP5305469 and the price is $194.09. I will also include a link with this part information.** Whirlpool W10393483 Electronic Control Board - AppliancePartsPros.com--** If you have any questions, please reply to this email or call us at the number below. ** Sincerely, Robin D. Customer Service AppliancePartsPros.com**team Phone:**1-877-477-7278****X 2022 Online:** Appliance Parts Pros.com Discount Appliance PartsFree Repair Help:** http://forum.appliancepartspros.com** Business Hours: 24/7 Customer Service, we are always open!
My washing machine will fill Ana drain but will not spin
Wow you had the same error code that I got. Have already replaced the lid lock, and the actuator, and have run out of things to try. The timer is quite expensive and I have already purchased the other two parts. The shifter assembly is around 135, but am ready to throw in the towel and get a repairman out to the house. Just sad to have troubles when the washer is just a year old. Thanks for your in depth explanation, I also heard that there is a fuse to check before replacing the other. Thanks for your help!
Originally Posted by: Lost1echo Thank you very much Eric! Hello LOST1ECHO, I am having the exact same issue as you with my MAYTAG CENTENNIAL . What happened in your case? Was the culprit the actuator ? Did you fix the problem? Tasha
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
How to check the clutch assembly on a Maytag Centennial Washing machine Commercial technology model MVWC6ESWWD0?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
What kind of problem are you having? The clutches on these are pretty durable, but they can wear out. Edited by user Sunday, February 26, 2023 2:11:06 PM(UTC)
| Reason: Not specified
