apostoln
#1 Posted : Tuesday, January 13, 2015 6:07:10 AM(UTC)
apostoln
UNIT WAS WORKING FINE. WE UNPLUGGED AND MOVED IT TO A NEW LOCATION. IN THE PROCESS WE REMOVED THE PEDESTAL AND REINSTALLED THE LEGS. UNIT WAS ON ITS SIDE DURING THAT PROCESS. TOOK DOOR OFF AND CLEANED THOROUGHLY. IT IS CONNECTED TO GROUNDED OUTLET BUT THE HOSES ARE CONNECTED TO A SINGLE COLD WATER SUPPLY OUTLET . NOW WE PLUGGED IT IN AND STARTED A NORMAL CYCLE. WE HEAR DOOR LOCK, THEN 41 MINUTES IS DISPLAYED. UNIT BEGINS TO FILL THEN STOPS AND 11 f IS DISPLAYED. WE HAVE UNPLUGGED, RESET, TRIED SHORT CYCLE TO NO AVAIL. SAME THING HAPPENS. ON DRAIN SPIN CYCLE IT DRAINS AND THEN GETS f 11 AGAIN. BEFORE GETTING A NEW UCC BOAD, IS THERE ANY OTHER THOUGHT OF WHAT COULD BE THE PROBLEM.
#2 Posted : Tuesday, January 13, 2015 7:35:01 AM(UTC)
Parts for Whirlpool GHW9250MT0 Washer - AppliancePartsPros.com
See tha attachment for the tech sheet.
Have you tried unplugging/replugging the relevant connectors?
Also check that a wire has not come loose.
You may even want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
FYI: I do not know if you are aware that all capitals means that you are yelling and is considered rude on the net.
File Attachment(s):
GHW9250.pdf (128kb) downloaded 1 time(s).
