SteveUrbana
#1 Posted : Wednesday, May 13, 2009 11:36:19 AM(UTC)
SteveUrbana
Rank:: Member
I'd like to purchase a Sears Elite dishwasher (Whirlpool) pump and motor assembly (8535150 Whirlpool part). I've found it on this site but wonder how difficult the replacement would be. (I'm quite handy.) It looks to me that after disconnection a hose or two and a few electric connections the unit lifts out from the inside, and would hence seem easy. Although, I can't seem to remove the rotor to have a good look at the pump. Any comments?
#2 Posted : Wednesday, May 13, 2009 11:51:39 AM(UTC)
Views messages in topic : 19,638
Here is the tech sheet for this unit, it icludes motor removal instructions.
https://www.servicematters.com/d...0Sheet%20-%208537797.pdf
SteveUrbana
#3 Posted : Wednesday, May 13, 2009 2:35:33 PM(UTC)
SteveUrbana
Rank:: Member
Thanks!! I removed the pump using these instructions -- no problem. Only issue is that I had to remove (unscrew) the plastic intake line stub before I could fully remove the pump unit, but not problem here.
SteveUrbana
#4 Posted : Thursday, May 14, 2009 8:02:49 AM(UTC)
SteveUrbana
Rank:: Member
The PDF instructions above instruct me to seal the unit with a lubricant. I presume it's talking about the main seal around the perimeter of the pump unit. What kind of lubricant should I use? Is the really necessary?
#5 Posted : Thursday, May 14, 2009 8:49:39 AM(UTC)
Stole this from a post by TechnicainBrian
Use rinse aid
No but it helps it slide in easier.
