lacoppari
#1 Posted : Wednesday, January 7, 2015 7:06:39 AM(UTC)
lacoppari
The washer quit today. The tub will not move in any cycle. I have checked three switches for continuity. One is right side of drum looks like a displacement switch. Second one is inertia switch also on right side. Third switch that is OK is at 6 o'clock below drum.
Wife says that for several weeks the spin light is not coming on even though the machine spins. Water will enter the tub but there is no motion. Any ideas?
lacoppari
#2 Posted : Wednesday, January 7, 2015 8:23:02 AM(UTC)
lacoppari
Update: I have a blown fuse on the motor control board. What would cause the fuse to blow? Bad motor? What should be replaced?
