mimdou
#1 Posted : Tuesday, January 6, 2015 11:45:46 AM(UTC)
mimdou
Hi
I have a Amana ARB9059CS (PARB9059CS1) fridge
Lights inside are working but that is it.
No power to the fan, the compressor, the starting relay.
I replaced the compressor start device and capacitor (the relay was bad), but it didn't fix the issue.
I turned the dial on the defrost timer until I heard a click, but still didn't work.
I am not sure what else I should check, and how
Herve
#2 Posted : Wednesday, January 7, 2015 1:53:22 AM(UTC)
Here are your parts includes a wiring diagram.
Parts for Amana ARB9059CS / PARB9059CS1 Refrigerator - AppliancePartsPros.com
Unplug the unit and check across the control thermostat with a meter.
It should be 0 ohms.
Alternatively.
Unplug the unit and short the two control thermostat wires together.
You may have to tape them so they do not short out to anything else.
Plug the unit in and if it fires up you know you have a bad control thermostat.
If it does not fire up.
Turn the defrost timer cam slowly 360 degrees just to be sure that you are not in a defrost cycle.
If it still does not fire up then odds are that you have a bad defrost. timer
