Freezer not working.. Heavy frost on back panel. . Was going to replace board, heater, and thermostat. . Need to verify if WR55X10942 is part for board, WR51X10055 is part for heater, and WR50X10068 part for thermostat, this model number does not seem to be common and does not show up on lists.... Thanks.....
Originally Posted by: disconnect_at&t  Freezer not working.. Heavy frost on back panel. . Was going to replace board, heater, and thermostat. . Need to verify if WR55X10942 is part for board, WR51X10055 is part for heater, and WR50X10068 part for thermostat, this model number does not seem to be common and does not show up on lists.... Thanks..... After watching this, and doing the tests, it appears the evap thermistor is defective, only get 12k ohms, with thermistor packed in ice, and have continuity on heater and thermostat tests. I can also run the defrost cycle with codes in test mode and see heater works. The test mode indicates evap thermistor is good and freezer thermistor is defective so replacing both.. GE Electronic Refrigerator Defrost Problem: http://youtu.be/BrSQz-5F1hs
