I bought a used Avanti mini fridge that had been converted to a kegerator. So far as I could tell, it had been working for its original owner. I got it home, plugged it in overnight to let it cool, and woke up this morning to a warm fridge. The compressor seems to be running, there's no clicking or anything to indicate it's turning off, and it seems to me (other than its lack of coolness) to be running like a normal fridge. I know nothing about fridge repair. I've been searching around trying to find information, but with so many models of fridges I'm afraid I'll get information that's not relevant to this model. I got the fridge pretty cheap considering it's been converted to a kegerator. (A new, already built kegerator will run $500-$1000 easily.) I'd like to see if I can fix it myself before either (a) taking it to a repair shop or (b) getting another mini fridge and saving the kegerator conversion parts from this one. I've attached images that may or may not help. Like I said, I'm totally new at this. If I need to provide any other information I'd be happy to. Thanks for any help! David1988 attached the following image(s):
I have no info on this unit. With luck someone else will jump in who has experience with it.
I can give you some general info. If the compressor is running (you can usually hear it but also should be able to feel it vibrating) and the unit is not cooling, then it is a sealed system problem and will be an expensive repair.
Could be moving it caused a freon leak.
Also if the unit was moved on it's side or a sever tilt, it should have been left standing upright for 24 hours before plugging it in. |
THIS FORUM IS DEAD!!!!!!! |
