bkmunchkin
#1 Posted : Sunday, December 14, 2014 4:11:19 PM(UTC)
bkmunchkin
Hello,
Our GE oven (bake and broil) is not working. The temp starts out at 100 on the display but instead of rising, after about 30 seconds, it clicks off. The problem was intermittent in the past and if you kept trying, it would eventually stay on and heat to the correct temp. Now, it consistently starts at 100 and then quickly turns off. The broil function is the same - display turns on but heating coil doesn't heat and display turns off after less than a minute.
Can you tell me what the problem is and which part is needed to fix it?
Thank you.
Betty
#2 Posted : Monday, December 15, 2014 6:30:23 AM(UTC)
Parts for GE JBP90GS1 Range - AppliancePartsPros.com
It sounds like a control board (timer) problem.
Unfortunately this part is no longer available.
