kbreezy
#1 Posted : Sunday, December 14, 2014 3:50:33 AM(UTC)
kbreezy
First thing I replaced thermostat . The coils still iced up. Then I replaced defrost board. Did not fix problem. Thus I replaced the whole control board did not fix promblem. I checked contunity on heater. It shows that the heater is good. I push door switch in 5 times heater came on . Push door switch 5 times again took it out of defrost. so heater did come on . It has the adaptive board. Help please frustrated.
#2 Posted : Sunday, December 14, 2014 5:35:27 AM(UTC)
Since you can force a defrost cycle all I can think of is that you received a bad adaptive defrost board.
[COLOR="Blue"]
Then I replaced defrost board. Did not fix problem. Thus I replaced the whole control board did not fix problem[/COLOR]
Though I am not sure what you mean when you say you replaced the whole control board.
