My range started beeping at random times. The oven would not heat. It would start to and then just stop. No fault codes were displayed on the control panel.
The range is about 7 years old. I replaced the control panel. The beeping has stopped but when I try and heat the oven, it displays the current temperature as the temperature I'm trying to heat it to and then beeps once. It then displays a fault code of 3d11. The broil and convection settings display "The feature is not available" message
Is the oven sensor bad too? Or was it just the sensor the whole time? Would a faulty sensor cause the oven beep randomly and disable the broil and convection?
I checked the sensor and it shows 1080 ohms so that isn't the problem. Maybe a faulty circuit board or the control panel I received is faulty?
