BrockSr
#1 Posted : Tuesday, December 9, 2014 5:18:37 AM(UTC)
BrockSr
Forgot the golden rule of unplugging the dryer. I dropped the screw driver around the door sensor and it got real BRIGHT. I checked the sensor, I only have a continuity tester, and there is continuity when the door sensor is pressed in (door closed). There's also continuity on the thermal sensor with both wires removed. Curious what to check now?
