Nick Good
#1 Posted : Sunday, December 7, 2014 8:11:02 PM(UTC)
Nick Good
Our GE GTWN2800D washer is making a loud metal on metal grinding sound during agitation and spin cycle. The drive pulley is grinding on a raised portion of the frame on the bottom front of the washer.
applianceman
#2 Posted : Monday, December 8, 2014 9:59:45 AM(UTC)
applianceman
I think you have the sagging apron issue, which is the brace that holds the tub up had bent down. They were one-piece aprons then some smart guy with GE decided they could use three-piece aprons and they will bend down causing this issue. This was a bad issue about 3-5 years ago and since then they have fixed the issue. I wrote about this problem on this page scroll down to the section titled sagging apron GE HydroWave Noisy Washer Repair Guide
