JAD315
#1 Posted : Sunday, December 7, 2014 6:22:42 PM(UTC)
JAD315
Bosch Dishwasher Makes Squealing/grinding Noise Mid Cycle. Noise Continues For Some Time After Shutting The Unit Off. However It Runs Fine When Turned Back On. Is This Repairable?
Servicer
#2 Posted : Tuesday, December 9, 2014 11:23:13 AM(UTC)
Servicer
Hello,
If the noise continues after the power switch is turned off, it's not coming from the dishwasher. On your model, when the power switch is turned off, power is cut to all of the other components within the unit. If you hear the noise only with the switch is turned on, the noise may be the drain motor, which is still available.
