Lady G
#1 Posted : Saturday, December 6, 2014 2:54:50 PM(UTC)
Lady G
i can hear fans running,I have checked the fan in freezer it is working,no frost a build up on coils,fridge is not cooling and freezer not freezing. Fan in the back of
fridge is running touched compressor it is warm to touch. what should i do?:confused:
#2 Posted : Sunday, December 7, 2014 4:34:31 AM(UTC)
Is the compressor running?
You can usually hear it but should also be able to feel it vibrating.
If it is and it is running all the time except when the unit goes through a defrost cycle and you get zero cooling then it is a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
