Gene or other experts, I'd need your help please.
For my GE GSL25JFPA BS side-by-side, the ice & water dispenser doesn't work either.
Board seems functional, as corresponding light comes on when switching between Water, Crushed and Cubed.
My problem is that the Ice Funnel (GE Part # WR17X11267) fell off the Housing Shield Disp (WR17X12152). There is a metal spring (WR49X10233) that came loose, but I don't know where it goes.
Took the whole front of the dispensing unit apart, but can't figure out how to re-attach this Ice Funnel to the Housing Shield. Tried all different ways to install that metal spring, but nothing seems right. Help, please !
Any advice would be greatly appreciated. Thank you !
I was wondering if you ever figured out how to replace the spring back correctly. I have the same problem and have been unable to find a picture anywhere of how to put the spring back on the funnel and housing. Thanks!
