backyardhockey
#1 Posted : Wednesday, December 3, 2014 9:16:27 AM(UTC)
backyardhockey
Series 80. Agitates and drains fine. But very loud hum/screech during rinse and spin (will try to post recording later). Rinse and spin not happening. Also, I found a spring underneath the washer. Saw other springs still connected near bottom. This one not as big. Thanx.
sidfink43
#2 Posted : Thursday, December 4, 2014 3:22:05 PM(UTC)
sidfink43
I am not sure I understand what is happening, when you say rinse and spin do you mean just the spin after the agitation cycle and after the rinse cycle?
I suggest you operate it with the cabinet off by by-passing the lid switch and see if you can determine the cause of the problem by watching it. Also sounds like some of the support springs are off or broken.
backyardhockey
#3 Posted : Thursday, December 4, 2014 5:25:35 PM(UTC)
backyardhockey
Ive added a picture of the mystery spring. I cant find one like this on any parts list. The noise is a rubbing/whir. Washer agitates and drains but no rinse or spinning at all. I have it in about 20 pieces right now. Coupler and clutch look good.
backyardhockey attached the following image(s):
sidfink43
#4 Posted : Thursday, December 4, 2014 5:38:33 PM(UTC)
sidfink43
That is the spring from the door of a Whirlpool or Kenmore Dryer. It does not belong to your washer and don't know how it got under the machine.
We really need more information, and you need to operate it with the cabinet off to see if you can tell what is wrong. Beginning to sound like the transmission, which you can tell if you observe and notice the clutch is not turning when it is in spin cycle.
backyardhockey
#5 Posted : Thursday, December 4, 2014 5:42:59 PM(UTC)
backyardhockey
Is there a way to post audio on this forum? I did record the noise its making.
backyardhockey
#6 Posted : Friday, December 5, 2014 2:39:15 PM(UTC)
backyardhockey
backyardhockey
#7 Posted : Tuesday, December 16, 2014 6:31:23 PM(UTC)
backyardhockey
UserPostedImage
The clutch (what the red arrow is pointing to, correct?) was not moving during the rinse, agitate, or spin cycles.
sidfink43
#8 Posted : Wednesday, December 17, 2014 10:03:32 AM(UTC)
sidfink43
Okay this does sound like a transmission issue, but first you should remove and inspect the clutch and clutch lining and related parts to see if there is a problem there. Look closely at the brakes and the brake cam.
backyardhockey
#9 Posted : Thursday, December 18, 2014 12:25:59 PM(UTC)
backyardhockey
UserPostedImage
So on this part, you can see that one of the fingers has broken of but the other is still there. Remember that the clutch does not spin during operation. Is this broken part enough to cause the washer not to spin?
sidfink43
#10 Posted : Thursday, December 18, 2014 12:45:46 PM(UTC)
sidfink43
Yep, that could do it.
Guest (5)
