Hi everyone, I have been trying to get my oven to work again but no such luck. At first,it was taking long to heat,the ignitor still glowed but slightly. I replace the ignitor,it worked great for about 3 days. Then the ignitor completly went out. In the process of checking it out,I also broke one the prongs on the Safety Gas valve .So I had to purchase both a new valve and ignitor.I installed them,but nothing. Im thinking either maybe I have to reset something,my connector is bad(the ignitor I bought only came with open wires and wire nuts) or I have the wires mixed up.I hate wiring,not good with it,but I tackle it none the less. Any advice with this would greatly appreciated.Thanks in advance!
Okie dokie,one of the connections just came off while I was connecting with a wire nut.It works now .Disregard post guys.Thanks!:o
