chuck vaughn
#1 Posted : Monday, December 1, 2014 1:35:50 PM(UTC)
chuck vaughn
roper dryer no heat .it starts , heating element seems to be good no broken wire ,i get continuity thru the thermal fuse. any help would be useful.
thanks
#2 Posted : Tuesday, December 2, 2014 12:47:11 AM(UTC)
Parts for Roper RED4340SQ1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
It will not be the thermal fuse on the blower as that kills power to both the heater and the motor.
First thing to check is the power.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Note: that on this unit both the heater and the timer use the full 240 so if the timer does not advance in timed dry then this also points towards a power problem.
File Attachment(s):
RED4340.pdf (507kb) downloaded 1 time(s).
Roper Dryer no heat (Dryer Repair)
by rogerd1961 12/27/2012 3:18:45 PM(UTC)
Roper Dryer No Heat Problem (Dryer Repair)
by schmocker 7/16/2012 1:17:00 PM(UTC)
