jomar09
#1 Posted : 16 years ago
jomar09
My Maytag Nepune washer tub drains, but water stays beneath the tub. I can hear it sloshing around when I rotate the tub. The exterior hoses are not crimped. How do I get the washer to drain completely?
Thank you!
#2 Posted : 16 years ago
Remove the front panel and check the pump and its hoses.
Here are the breakdown diagrams and Replacement parts for MAYTAG MAH5500BWQ | AppliancePartsPros.com
neptune help
#3 Posted : 16 years ago
neptune help
Hello,
The sloshing sound you hear when rotating the inner tub is the balance ring which contains liquid and is an important component of the Neptune's balancing system.
Hear the new neptune bearing song at NEPTUNE BEARING.
