After about 4 hours of cooking a turkey the oven just stop working and also the spark plug on the stove stop working but the stove work if I use a match to light it. Everything on the digital panel is out but the light right above the lower oven knob is blinking when it on the off position if I turn the knob to the on position the light will go off. About 4yrs ago on this same stove the spark plug was also not working I changed the spark module and That fix it. Can someone please can help me with this problem.
Thanks! Kwan 650-270-3782
