gerald49sf
#1 Posted : Friday, November 28, 2014 6:17:52 AM(UTC)
gerald49sf
The dishwasher control panel is completely dead, no lights at all. I have checked that power is good entering washer, I verified and tested the thermal fuse while installed and power is passing through the fuse and verified the door switch is functioning correctly. Is there anything else i can check to determine the casue? Are there more fuses on circuit boards or check to make sure they control panel is getting power etc. Are there any schematics available for this dishwasher?
