When you close the refrigerator door, the top freezer door pops open 3-4". What can be done to correct this?
Check that the fridge is level or leaning slightly towards the back.
Also check that the freezer door seal is sealing correctly. Note the hinge side to ensure it is not catching and trying to fold over. If it is doing this, a light coating of vaseline or white lithium grease on this side of the frame should help is slide closed properly |
THIS FORUM IS DEAD!!!!!!! |
