Samsung Electric Stove Top - Spark on Temperature Knob Greetings all, Glad to find such a helpful forum. Our 2 year old Samsung Electric NE595R0ABS was operating almost perfectly for Thanksgiving. The left Temperature Knob malfunctioned and had a sudden blue spark. Oven at the moment does not operate, and I've checked the circuit breaker with no issues. Would replacing the Regulator solve the circuit issue? Or is it a bigger replacement such as the mother board. Apologies for the lack of correct terminology. Will be checking for a current later. I've attached more photos:
Here are your parts Parts for Samsung NE595R0ABSR/AA-0000 / Range - AppliancePartsPros.comSounds like the spark also blew the control board. You will have to replace the board and the infinite switch that sparked. Note that I do not have access to tech info on Samsungs and could not find a fuse in the parts listing so am assuming that it is a board problem. |
THIS FORUM IS DEAD!!!!!!! |
